Salta al contenuto principale
Shower Handle O-ring Replacement
Cosa ti serve
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: passo 1, immagine 1 di 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: passo 2, immagine 1 di 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    Reverse position of pliers pictured
    ajbdo1959 - Replica
  3. Shower Handle O-ring  Replacement: passo 3, immagine 1 di 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
    ajbdo1959 - Replica
  4. Shower Handle O-ring  Replacement: passo 4, immagine 1 di 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: passo 5, immagine 1 di 2 Shower Handle O-ring  Replacement: passo 5, immagine 2 di 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
2 Commenti
I have to change my shower handle, but the plumber asking me to change the shower valve also. But I can’t see any reason to replace the shower valve, is it really necessary to change it when changing shower handle.
Thanks.
Rose Geiger - Replica
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 57
Ultimi 30 Giorni: 280
Tutti i Tempi: 20,827
