Salta al contenuto principale
Shop-Vac MC150A Power Unit Assembly Replacement
Cosa ti serve
  1. Shop-Vac MC150A Power Unit Assembly Replacement, Unlatch the power unit assembly: passo 1, immagine 1 di 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Unit Assembly Replacement, Remove the top cover: passo 2, immagine 1 di 2 Shop-Vac MC150A Power Unit Assembly Replacement, Remove the top cover: passo 2, immagine 2 di 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Unit Assembly Replacement: passo 3, immagine 1 di 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Unit Assembly Replacement: passo 4, immagine 1 di 1
    • Separate the power unit assembly from the cover.
Conclusione
Ngunlian
Membro da: 02/08/16
732 Reputazione
5 Guide realizzate
IUPUI, Team 1-2, Baechle Spring 2016 Membro di IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,224
