Introduzione
If you have a short or cut power cable you should replace it with a new one. This guide will help you through replacing the power cable attached to the vacuum.
Cosa ti serve
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Pull out and disconnect the four spade connectors from the switch module.
Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
Altre 3 persone hanno completato questa guida.
Un commento
How and where do I order a power cord? Just any power? Or a specific for shop vac.
