Introduzione
This guide will teach you how to remove and replace the motor for the MC150A Shop-Vac.
Cosa ti serve
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Pull out and disconnect the four spade connectors from the switch module.
Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
Altre 6 persone hanno completato questa guida.
2 Commenti
Where do I buy a new motor?????
Yeah that's what we all would like to know, removing is the easy part
