Salta al contenuto principale
Shop-Vac MC150A Motor Replacement
Cosa ti serve
  1. Shop-Vac MC150A Motor Replacement, Unlatch the power unit assembly: passo 1, immagine 1 di 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Motor Replacement, Remove the top cover: passo 2, immagine 1 di 2 Shop-Vac MC150A Motor Replacement, Remove the top cover: passo 2, immagine 2 di 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Motor Replacement: passo 3, immagine 1 di 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Motor Replacement: passo 4, immagine 1 di 1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Motor Replacement, Disconnect the switch: passo 5, immagine 1 di 3 Shop-Vac MC150A Motor Replacement, Disconnect the switch: passo 5, immagine 2 di 3 Shop-Vac MC150A Motor Replacement, Disconnect the switch: passo 5, immagine 3 di 3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: passo 6, immagine 1 di 2 Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: passo 6, immagine 2 di 2
    • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
  7. Shop-Vac MC150A Motor Replacement: passo 7, immagine 1 di 2 Shop-Vac MC150A Motor Replacement: passo 7, immagine 2 di 2
    • During reassembly, be sure to reattach the green ground wire clip to the bracket.
  8. Shop-Vac MC150A Motor Replacement: passo 8, immagine 1 di 1
    • Separate the clip from the green wire and transfer it to the replacement motor.
  9. Shop-Vac MC150A Motor Replacement, Motor: passo 9, immagine 1 di 2 Shop-Vac MC150A Motor Replacement, Motor: passo 9, immagine 2 di 2
    • Remove the motor bracket.
  10. Shop-Vac MC150A Motor Replacement: passo 10, immagine 1 di 1
    • Turn the part over to the other side.
    • Use the socket wrench remove the bolt securing the aluminum plate.
  11. Shop-Vac MC150A Motor Replacement: passo 11, immagine 1 di 1
    • Unscrew the two Phillips head screws holding the cover to the motor.
    • After removing the cover to the motor, you can replace the motor.
Conclusione
Altre 6 persone hanno completato questa guida.
Ngunlian
Membro da: 02/08/16
732 Reputazione
5 Guide realizzate
IUPUI, Team 1-2, Baechle Spring 2016 Membro di IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Membri
13 Guide realizzate
2 Commenti
Where do I buy a new motor?????
Gerald Mikel - Replica
Yeah that's what we all would like to know, removing is the easy part
Junkyard_Boxer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 102
Ultimi 30 Giorni: 442
Tutti i Tempi: 25,474
