Salta al contenuto principale
Shenzhou k680e Silicone Grease Replacement
Cosa ti serve
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: passo 1, immagine 1 di 1
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: passo 2, immagine 1 di 1
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: passo 3, immagine 1 di 1
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: passo 4, immagine 1 di 1
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: passo 5, immagine 1 di 1
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: passo 6, immagine 1 di 1
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: passo 7, immagine 1 di 1
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: passo 8, immagine 1 di 1
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: passo 9, immagine 1 di 2 Shenzhou k680e Silicone Grease Replacement: passo 9, immagine 2 di 2
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: passo 10, immagine 1 di 1
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: passo 11, immagine 1 di 1
    • Squeeze new thermal paste onto the chips.
Conclusione
Yizhen Qu
Membro da: 09/20/20
217 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 648
