Salta al contenuto principale
Sharper Image SVC430 Tripod Nut Replacement
Cosa ti serve
  1. Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: passo 1, immagine 1 di 2 Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: passo 1, immagine 2 di 2
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Tripod Nut Replacement: passo 2, immagine 1 di 2 Sharper Image SVC430 Tripod Nut Replacement: passo 2, immagine 2 di 2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Tripod Nut Replacement: passo 3, immagine 1 di 3 Sharper Image SVC430 Tripod Nut Replacement: passo 3, immagine 2 di 3 Sharper Image SVC430 Tripod Nut Replacement: passo 3, immagine 3 di 3
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Tripod Nut Replacement: passo 4, immagine 1 di 2 Sharper Image SVC430 Tripod Nut Replacement: passo 4, immagine 2 di 2
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Tripod Nut Replacement: passo 5, immagine 1 di 1
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Tripod Nut Replacement: passo 6, immagine 1 di 3 Sharper Image SVC430 Tripod Nut Replacement: passo 6, immagine 2 di 3 Sharper Image SVC430 Tripod Nut Replacement: passo 6, immagine 3 di 3
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Tripod Nut Replacement: passo 7, immagine 1 di 1
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Tripod Nut Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Tripod Nut Replacement: passo 9, immagine 1 di 1
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Tripod Nut Replacement: passo 10, immagine 1 di 1
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Tripod Nut Replacement, Tripod Nut: passo 11, immagine 1 di 1
    • Locate the two screws that attach the tripod nut to the device.
  12. Sharper Image SVC430 Tripod Nut Replacement: passo 12, immagine 1 di 2 Sharper Image SVC430 Tripod Nut Replacement: passo 12, immagine 2 di 2
    • Unscrew the two screws located on the back of the half that the tripod nut is located.
    • Once the screws are removed, the tripod nut can easily be removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 215
