Salta al contenuto principale
Sharper Image SVC430 Mount Rubber Washer Replacement
  1. Sharper Image SVC430 Mount Rubber Washer Replacement, Mount Rubber Washer: passo 1, immagine 1 di 1
    • Locate the knobs on either side of the mount screw.
  2. Sharper Image SVC430 Mount Rubber Washer Replacement: passo 2, immagine 1 di 1
    • Twist the knob so it comes off from the mount.
  3. Sharper Image SVC430 Mount Rubber Washer Replacement: passo 3, immagine 1 di 1
    • Once you have twisted apart the knobs, the rubber washer should easily fall out of the base.
    • This component is identical on the other mount, so this guide applies for both mounts.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 121
