Salta al contenuto principale
Introduzione
Removing the back panel is a prerequisite to any replacement or repair you need to do. When the back panel is removed the electronics and the speaker are visible and available to be removed or repaired.
Parti
Nessuna parte specificata.
  1. Unplug the speaker before doing any work on it. Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
    • Unplug the speaker before doing any work on it.
    • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
  2. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  3. Remove the back panel.
    • Remove the back panel.
Conclusione
Linda Freund
Membro da: 06/08/2017
205 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 90
