Salta al contenuto principale
Sharp-EL-531xg Battery Replacement
Cosa ti serve
  1. Sharp-EL-531xg Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: passo 2, immagine 1 di 2 Sharp-EL-531xg Battery Replacement: passo 2, immagine 2 di 2
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: passo 3, immagine 1 di 1
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: passo 4, immagine 1 di 3 Sharp-EL-531xg Battery Replacement: passo 4, immagine 2 di 3 Sharp-EL-531xg Battery Replacement: passo 4, immagine 3 di 3
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: passo 5, immagine 1 di 1
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: passo 6, immagine 1 di 1
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: passo 7, immagine 1 di 2 Sharp-EL-531xg Battery Replacement: passo 7, immagine 2 di 2
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 62
Tutti i Tempi: 707
