Cosa ti serve
To replace the T-Con board it is not necessary to remove the base.
Lay the the TV flat on a padded surface.
To reassemble all the parts easily, mark with a permanent marker the location of the screws you are removing.
4 screws hold the nd fixing angle.
Remove the 7 screws holding the lug angle top.
Then remove only the bottom screws from the tray fixing angles, leaving the top screws attached to the lug angle top.
To disconnect the ribbon cables, lift the brown tab on the connector.
Make sure the ribbons are positioned correctly in the connector when reassembling the new board.
There are two pads glued under the board (see yellow marks in the picture): use a heat gun to soften them and then gently pry them to detach the board from the frame.
There are also 4 tabs holding the board: gently pull the board to release it, after the pads are disconnected.
Reposition the pads on the chassis before installing the new board.
