Salta al contenuto principale
Sharp EL-510RN Calculator Battery Replacement
Cosa ti serve
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: passo 1, immagine 1 di 2 Sharp EL-510RN Calculator Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: passo 2, immagine 1 di 3 Sharp EL-510RN Calculator Battery Replacement: passo 2, immagine 2 di 3 Sharp EL-510RN Calculator Battery Replacement: passo 2, immagine 3 di 3
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: passo 3, immagine 1 di 3 Sharp EL-510RN Calculator Battery Replacement: passo 3, immagine 2 di 3 Sharp EL-510RN Calculator Battery Replacement: passo 3, immagine 3 di 3
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: passo 4, immagine 1 di 3 Sharp EL-510RN Calculator Battery Replacement: passo 4, immagine 2 di 3 Sharp EL-510RN Calculator Battery Replacement: passo 4, immagine 3 di 3
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: passo 5, immagine 1 di 1
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Conclusione
Harish Kugathasalingam
Membro da: 10/21/22
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 18
Tutti i Tempi: 300
