Salta al contenuto principale
Sharp Aquos LC13B2UA Front Case Replacement
Cosa ti serve
  1. Sharp Aquos LC13B2UA Front Case Replacement, Stand: passo 1, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement, Stand: passo 1, immagine 2 di 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Front Case Replacement: passo 2, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement: passo 2, immagine 2 di 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Front Case Replacement, Back Case: passo 3, immagine 1 di 3 Sharp Aquos LC13B2UA Front Case Replacement, Back Case: passo 3, immagine 2 di 3 Sharp Aquos LC13B2UA Front Case Replacement, Back Case: passo 3, immagine 3 di 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Front Case Replacement: passo 4, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Front Case Replacement: passo 5, immagine 1 di 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: passo 6, immagine 1 di 3 Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: passo 6, immagine 2 di 3 Sharp Aquos LC13B2UA Front Case Replacement, Motherboard: passo 6, immagine 3 di 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Front Case Replacement: passo 7, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement: passo 7, immagine 2 di 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Front Case Replacement: passo 8, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement: passo 8, immagine 2 di 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Front Case Replacement: passo 9, immagine 1 di 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Front Case Replacement, Power Button: passo 10, immagine 1 di 3 Sharp Aquos LC13B2UA Front Case Replacement, Power Button: passo 10, immagine 2 di 3 Sharp Aquos LC13B2UA Front Case Replacement, Power Button: passo 10, immagine 3 di 3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
  11. Sharp Aquos LC13B2UA Front Case Replacement, Top Buttons: passo 11, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement, Top Buttons: passo 11, immagine 2 di 2
    • Unscrew the two 4mm Phillips screws.
    • Lift the buttons off the front case.
  12. Sharp Aquos LC13B2UA Front Case Replacement, Front Case: passo 12, immagine 1 di 2 Sharp Aquos LC13B2UA Front Case Replacement, Front Case: passo 12, immagine 2 di 2
    • Remove the eight 10mm screws connecting the two speakers to the front case.
  13. Sharp Aquos LC13B2UA Front Case Replacement: passo 13, immagine 1 di 3 Sharp Aquos LC13B2UA Front Case Replacement: passo 13, immagine 2 di 3 Sharp Aquos LC13B2UA Front Case Replacement: passo 13, immagine 3 di 3
    • Remove the two black tape strips securing the audio cables to the case.
    • Lift the audio cable from the plastic prongs securing it to the front case
    • The speakers can now be removed.
  14. Sharp Aquos LC13B2UA Front Case Replacement: passo 14, immagine 1 di 3 Sharp Aquos LC13B2UA Front Case Replacement: passo 14, immagine 2 di 3 Sharp Aquos LC13B2UA Front Case Replacement: passo 14, immagine 3 di 3
    • To remove the LED circuit at the base of the front casing, unscrew the two 5mm Phillips screws.
    • Lift the circuit to remove the plastic LED casing.
Conclusione
Robert Hobson
Membro da: 01/20/11
1.290 Reputazione
9 Guide realizzate
Cal Poly, Team 1-11, Amido Winter 2011 Membro di Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,806
