Salta al contenuto principale
Introduzione
This guide will show how to replace the back panel of your Sharp Aquos LC13B2UA LCD Television.
Parti
Nessuna parte specificata.
  1. Place the TV face down on a flat smooth surface as to not scratch the screen. Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Lift the stand off the television. Lift the stand off the television.
    • Lift the stand off the television.
  3. Remove the two back panels by prying them out with your hands. Remove the two back panels by prying them out with your hands. Remove the two back panels by prying them out with your hands.
    • Remove the two back panels by prying them out with your hands.
  4. Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge. Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Using your hands, gently lift and remove the back case of the television.
    • Using your hands, gently lift and remove the back case of the television.
Conclusione
Robert Hobson
Membro da: 20/01/2011
1.275 Reputazione
9 Guide realizzate
Cal Poly, Team 1-11, Amido Winter 2011 Membro di Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Membri
9 Guide realizzate
How do you remove the casing of a sharp LC26SB25E ? Please.
alan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 3,574
