Salta al contenuto principale
Shark Vertex Pro IZ682H Pre-Motor Filter Replacement
Cosa ti serve
  1. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Battery: passo 1, immagine 1 di 1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: passo 2, immagine 1 di 1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Pre-Motor Filter: passo 3, immagine 1 di 2 Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Pre-Motor Filter: passo 3, immagine 2 di 2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: passo 4, immagine 1 di 2 Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: passo 4, immagine 2 di 2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
Conclusione
Tyree Brooks
Membro da: 10/26/22
486 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Membro di UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 309
