Salta al contenuto principale
Shark Vertex Pro IZ682H Brush Roller Replacement
  1. Shark Vertex Pro IZ682H Brush Roller Replacement, Brush Roller: passo 1, immagine 1 di 1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
Conclusione
Tyree Brooks
Membro da: 10/26/22
486 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Membro di UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Membri
5 Guide realizzate
Un commento
Hey there, where can I find the replacement rollers? I have been looking around and I do not see any that name the product exactly or in listed in compatible. Are they standard size or something like that?
John Melo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 63
Tutti i Tempi: 1,051
