Salta al contenuto principale
Shark Ultimate Professional Mode Display Replacement
Cosa ti serve
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: passo 1, immagine 1 di 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: passo 1, immagine 2 di 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: passo 1, immagine 3 di 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: passo 2, immagine 1 di 2 Shark Ultimate Professional Mode Display Replacement: passo 2, immagine 2 di 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: passo 3, immagine 1 di 3 Shark Ultimate Professional Mode Display Replacement: passo 3, immagine 2 di 3 Shark Ultimate Professional Mode Display Replacement: passo 3, immagine 3 di 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: passo 4, immagine 1 di 3 Shark Ultimate Professional Mode Display Replacement: passo 4, immagine 2 di 3 Shark Ultimate Professional Mode Display Replacement: passo 4, immagine 3 di 3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: passo 5, immagine 1 di 2 Shark Ultimate Professional Mode Display Replacement: passo 5, immagine 2 di 2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: passo 6, immagine 1 di 2 Shark Ultimate Professional Mode Display Replacement: passo 6, immagine 2 di 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: passo 7, immagine 1 di 3 Shark Ultimate Professional Mode Display Replacement: passo 7, immagine 2 di 3 Shark Ultimate Professional Mode Display Replacement: passo 7, immagine 3 di 3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
Conclusione
Drew Carff
Membro da: 10/23/17
868 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G4, Leahy Fall 2017 Membro di USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 688
