Salta al contenuto principale
Shark Ultimate Professional Heat Plate Replacement
Cosa ti serve
  1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: passo 1, immagine 1 di 3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: passo 1, immagine 2 di 3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: passo 1, immagine 3 di 3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Heat Plate Replacement: passo 2, immagine 1 di 2 Shark Ultimate Professional Heat Plate Replacement: passo 2, immagine 2 di 2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Heat Plate Replacement: passo 3, immagine 1 di 1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Heat Plate Replacement: passo 4, immagine 1 di 3 Shark Ultimate Professional Heat Plate Replacement: passo 4, immagine 2 di 3 Shark Ultimate Professional Heat Plate Replacement: passo 4, immagine 3 di 3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Heat Plate Replacement: passo 5, immagine 1 di 2 Shark Ultimate Professional Heat Plate Replacement: passo 5, immagine 2 di 2
    • Remove two screws (left and right) affixed to circuit board.
Conclusione
Altre 3 persone hanno completato questa guida.
Drew Carff
Membro da: 10/23/17
868 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G4, Leahy Fall 2017 Membro di USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Membri
10 Guide realizzate
3 Commenti
This is an incomplete guide. Why even put it up. So silly and ridiculous. Not Good at all.
Muhammad Ahmad - Replica
Where is the part about the heat plate?
Nealy Moxam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,167
