Salta al contenuto principale
Shark Steam Pocket Mop Water Tank / Bladder Replacement
Cosa ti serve
  1. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: passo 1, immagine 1 di 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: passo 1, immagine 2 di 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Back Panel: passo 1, immagine 3 di 3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: passo 2, immagine 1 di 2 Shark Steam Pocket Mop Water Tank / Bladder Replacement, Water Tank / Bladder: passo 2, immagine 2 di 2
    • Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
  3. Shark Steam Pocket Mop Water Tank / Bladder Replacement: passo 3, immagine 1 di 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement: passo 3, immagine 2 di 3 Shark Steam Pocket Mop Water Tank / Bladder Replacement: passo 3, immagine 3 di 3
    • Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder.
    • Then gently lift the water tank / bladder out of its plastic housing. and turn it over.
    • To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
Conclusione
Jacob Howe
Membro da: 10/10/17
549 Reputazione
5 Guide realizzate
USF Tampa, Team S13-G7, Cagle Fall 2017 Membro di USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 634
