Salta al contenuto principale
Shark Steam Pocket Mop Steam Head Hose Replacement
Cosa ti serve
  1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: passo 1, immagine 1 di 3 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: passo 1, immagine 2 di 3 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: passo 1, immagine 3 di 3
    • Start by removing this quarter inch Phillips head screw
    • Next remove the two 1/8th inch Phillips head screws at the bottom of the connector piece.
    • Next remove the nine 1/8th inch Phillips head screws along the base of the steam head connection.
    • Next remove the two 1/8th inch Phillips head screws along the base of the steam head connector.
  2. Shark Steam Pocket Mop Steam Head Hose Replacement: passo 2, immagine 1 di 3 Shark Steam Pocket Mop Steam Head Hose Replacement: passo 2, immagine 2 di 3 Shark Steam Pocket Mop Steam Head Hose Replacement: passo 2, immagine 3 di 3
    • Once all the screws are removed and the baseplate of the steam head connection has been placed aside, gently remove the connector from the bottom of the base.
    • Gently remove the end caps of the hinge piece of the connector piece with your fingers.
    • Gently remove the host connection from the back plate.
    Is there a place I can buy the steam hose to replace? Mine has fallen apart but machine works fully otherwise!
    Amy - Replica
  3. Shark Steam Pocket Mop Steam Head Hose Replacement: passo 3, immagine 1 di 2 Shark Steam Pocket Mop Steam Head Hose Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use your tweezers to remove the metal ring holding the hose to the plastic end piece and replace the hose / bit as needed.
    Where can I find a replacement hose? Can i use a plain silicone tubing?
    Helita Bauer - Replica
Conclusione
Jacob Howe
Membro da: 10/10/17
549 Reputazione
5 Guide realizzate
USF Tampa, Team S13-G7, Cagle Fall 2017 Membro di USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Membri
10 Guide realizzate
2 Commenti
Ok, but where do I get a replacement hose?
semajrolyat - Replica
Same question as semajrolyat: where to source replacement hose?
CLIFTON CHANG - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,938
