Salta al contenuto principale
Shark Steam Pocket Mop Power Cable Replacement
Cosa ti serve
  1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: passo 1, immagine 1 di 3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: passo 1, immagine 2 di 3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: passo 1, immagine 3 di 3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: passo 2, immagine 1 di 2 Shark Steam Pocket Mop Power Cable Replacement, Power Cable: passo 2, immagine 2 di 2
    • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
    • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
    • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
Conclusione
Jacob Howe
Membro da: 10/10/17
549 Reputazione
5 Guide realizzate
USF Tampa, Team S13-G7, Cagle Fall 2017 Membro di USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,658
