Salta al contenuto principale
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement
Cosa ti serve
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: passo 1, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: passo 1, immagine 2 di 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 2, immagine 1 di 1
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 3, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 3, immagine 2 di 2
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 4, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 4, immagine 2 di 2
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 5, immagine 1 di 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 5, immagine 2 di 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 5, immagine 3 di 3
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 6, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 6, immagine 2 di 2
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 7, immagine 1 di 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 7, immagine 2 di 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 7, immagine 3 di 3
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 8, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 8, immagine 2 di 2
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 9, immagine 1 di 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 9, immagine 2 di 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 9, immagine 3 di 3
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 10, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: passo 10, immagine 2 di 2
    • Wiggle the brush roller upwards from the left and right side slots.
Conclusione
Daniel Ceja
Membro da: 01/24/19
277 Reputazione
2 Guide realizzate
Cal Poly, Team S19-G3, White Winter 2019 Membro di Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 997
