Salta al contenuto principale
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
Cosa ti serve
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: passo 1, immagine 1 di 2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: passo 1, immagine 2 di 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 2, immagine 1 di 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 2, immagine 2 di 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 2, immagine 3 di 3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 3, immagine 1 di 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 3, immagine 2 di 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 3, immagine 3 di 3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 4, immagine 1 di 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 4, immagine 2 di 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: passo 4, immagine 3 di 3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Conclusione
Cal Poly, Team S19-G3, White Winter 2019 Membro di Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Membri
12 Guide realizzate
Un commento
What is the motor PN and where can I get one?
Dennis Meece - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,434
