Salta al contenuto principale
Shark Rotator Powered Lift-Away Speed Headlight Replacement
Cosa ti serve
  1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: passo 1, immagine 1 di 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: passo 1, immagine 2 di 2
    • Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 2, immagine 1 di 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 2, immagine 2 di 2
    • Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
  3. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 3, immagine 1 di 1
    • Using a T20 screwdriver remove five 15.9 mm screws on the outside of the cover.
  4. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 4, immagine 1 di 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 4, immagine 2 di 2
    • Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
  5. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 5, immagine 1 di 1
    • Using a T20 screwdriver, remove two 13.4 mm screws from under the wheels.
  6. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 6, immagine 1 di 1
    • Using a T20 screwdriver, remove two 15.9 mm screws behind the vacuum wheels.
  7. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 7, immagine 1 di 1
    • Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
  8. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 8, immagine 1 di 1
    • Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
  9. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 9, immagine 1 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 9, immagine 2 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 9, immagine 3 di 3
    • Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
  10. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 10, immagine 1 di 1
    • Separate the front assembly cover from the vacuum.
  11. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 11, immagine 1 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 11, immagine 2 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 11, immagine 3 di 3
    • Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
  12. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 12, immagine 1 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 12, immagine 2 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 12, immagine 3 di 3
    • Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
  13. Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 13, immagine 1 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 13, immagine 2 di 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: passo 13, immagine 3 di 3
    • Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S4-G6, White Fall 2018 Membro di Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,181
