Introduzione
When the Shark Rotator Powered Lift-Away is difficult to maneuver or fails to pick up dirt, inspect the roller brush for clogs or damage. Excessive obstructions will cause the vacuum to not operate as intended.
Strumenti
Parti
Nessuna parte specificata.
Push lift away button and pull the handle up to separate the body from the wand section.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head.
The 13 Philips screws are Torxt 25 screws not philips head screws it’s a Special torx drive tool.
You forgot to explain how to remove the two silver end caps one of them has a philips head screw that has to be removed from the inside,
and it’s hard to find because it’s usually full of lint.
Remove white cap with a Flathead screwdriver or any other wedge-like tool.
You forgot to remove the two end caps by prying them off with a flat head screw driver, the one on the motor drive end has a hidden
philips head screw that has to be removed from the inside before prying off, I know from experience
Altre 6 persone hanno completato questa guida.
12 Commenti
Same. Need a new brush bar.
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
Does anyone get a reply?
This would be extremely helpful if it also identified the replacement part and where to find it. I’ve been searching for an NV752 replacement brushroll for a month.
I have a NV751. Where do you get a replacement brush roll for it?
I see so many people on here needing a new brush roll for the Navigator, myself included. After looking online for MONTHS without any resolution, I can only assume they don't sell just the brush roll and want you to but the $130 motorized floor nozzle that includes the brush roll just to make money. What a joke! Spend big money on a very good vacuum, but Shark doesn't sell a simple (and common) replacement part? That's just crap! I tried calling their support number, but never got connected to an actual person - ever! Better off buying a Dyson, I guess…
This has been a bit of a frustration for me as well. I did contact Shark Customer Service, and they will give a discount as a “courtesy” for this mess they have created with this great series of vacuums. They billed me $51 for the floor assembly. The Uv795 is such a great vacuum and once you get a hold of Shark they are pretty darn good in taking care of existing customers. My vacuum works fine, just needs a new brush roller. This way, I pay $30 more than the cost of a part that does not exist (according to Shark), and the vacuum is good to go for a long time to come. Good luck to all.
I am Cameron Ngai, a contributor to this article. This page was part of an assignment for our technical writing class at Cal Poly, so we do not know anything beyond what we figured out to write this page. I only just revisited this page after being reminded by an I-fixit email and noticed this thread. I apologize for not being able to help any further and wish you luck in your endeavors.
My wife ordered one from Walmart, but they sent the one for the Navigator which did not fit! We had to order the entire Brush head assembly
from Shark.com
I have a Shark NV682, which I understand is same as NV680 and NV681. I’ve been searching for a brush replacement as well, finally found this video and after reading these comments I think the answer is YOU CAN’T! I’m not a youtube guy but someone should save the rest of the world aggravation and post “If you have THIS Model XXX” Shark Vacuum your only option is to buy the entire head power unit. Or, if there is a work around (another brush will work) that would be great to know as well.
