Introduzione
When the Shark Rotator Powered Lift-Away is difficult to maneuver or fails to pick up dirt, inspect the roller brush for clogs or damage. Excessive obstructions will cause the vacuum to not operate as intended.
Strumenti
Parti
Nessuna parte specificata.
Push lift away button and pull the handle up to separate the body from the wand section.
Remove white cap with a Flathead screwdriver or any other wedge-like tool.
Altre 6 persone hanno completato questa guida.
12 Commenti
Same. Need a new brush bar.
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
Does anyone get a reply?
