Salta al contenuto principale
Shark Rotator Powered Lift-Away Brush Belt Replacement
Cosa ti serve
  1. Shark Rotator Powered Lift-Away Brush Belt Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: passo 1, immagine 1 di 2 Shark Rotator Powered Lift-Away Brush Belt Replacement, Shark Rotator Powered Lift-Away Head Nozzle Disassembly: passo 1, immagine 2 di 2
    • Push the lift away button and pull the handle up to separate the body from the wand section.
  2. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 2, immagine 1 di 1
    • Push lift away button on the wand then lift up on the top section to separate.
  3. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 3, immagine 1 di 2 Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 3, immagine 2 di 2
    • Tilt the wand shaft backwards for convenient.
  4. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 4, immagine 1 di 2 Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 4, immagine 2 di 2
    • Lay the head nozzle piece upside down.
    • Rotate the three gray taps to the unlock position.
  5. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 5, immagine 1 di 1
    • With your fingers, pry and pull the brush cage open.
  6. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 6, immagine 1 di 2 Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 6, immagine 2 di 2
    • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
    • Be sure to keep track of which screws go into which hole.
    • Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
    • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
    • Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
  7. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 7, immagine 1 di 1
    • Lift up the top cover now that all of the screws have been removed.
  8. Shark Rotator Powered Lift-Away Brush Belt Replacement, Brush Belt: passo 8, immagine 1 di 1
    • Pry tab out with a flat head screwdriver or any wedge-like tool.
  9. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 9, immagine 1 di 3 Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 9, immagine 2 di 3 Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 9, immagine 3 di 3
    • Gently press in on brush to detach.
    • Pull brush down and out.
  10. Shark Rotator Powered Lift-Away Brush Belt Replacement: passo 10, immagine 1 di 1
    • Slide the belt off of the gear.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S9-G3, Banghart Fall 2017 Membro di Cal Poly, Team S9-G3, Banghart Fall 2017
CPSU-BANGHART-F17S9G3
4 Membri
12 Guide realizzate
Un commento
where did you get new belts? I bought a set from Amazon for a Shark NV752 and the belts are a bit to large.
John Doe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 95
Tutti i Tempi: 14,965
