Introduzione
If the brush does not spin and the motor still works, then the brush belt may be worn down or damaged.
This guide will aid in replacing that belt.
Cosa ti serve
Push the lift away button and pull the handle up to separate the body from the wand section.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
Altre 6 persone hanno completato questa guida.
