Salta al contenuto principale
Shark Rocket Professional Secondary Filters Replacement
  1. Shark Rocket Professional Secondary Filters Replacement, Dust Cup: passo 1, immagine 1 di 2 Shark Rocket Professional Secondary Filters Replacement, Dust Cup: passo 1, immagine 2 di 2
    • First, locate the button that says "Dust Cup". It is right next to the power button at the base of the handle.
    • Press the button down completely; you should feel a click.
  2. Shark Rocket Professional Secondary Filters Replacement: passo 2, immagine 1 di 1
    • Grab the handle of the dust cup, then pull up and away from the vacuum.
    • You must press the button and pull the dust cap simultaneously at first to release the latch.
  3. Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: passo 3, immagine 1 di 3 Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: passo 3, immagine 2 di 3 Shark Rocket Professional Secondary Filters Replacement, Secondary Filters: passo 3, immagine 3 di 3
    • As you look beneath the base of the dust cup, you will see a white foam filter. Remove this filter with your fingers.
  4. Shark Rocket Professional Secondary Filters Replacement: passo 4, immagine 1 di 1
    • Removing the first filter will reveal a second, thicker foam filter. Remove this as well.
    • Shark recommends that you rinse and air dry these filters monthly.
    • Remember to replace the filters in the correct order.
  5. Shark Rocket Professional Secondary Filters Replacement: passo 5, immagine 1 di 1
    • A dust filter is located within the dust cup. To access it, open the dust cup by pressing the orange tab on the front and pulling up on the handle.
  6. Shark Rocket Professional Secondary Filters Replacement: passo 6, immagine 1 di 1
    • Find the cylindrical screen in the center of the dust cap, grab the top, and pull it straight out.
    • If this filter is dirty, shake it or rinse it off to clean it.
Conclusione
Theo Watkins
Membro da: 01/23/18
356 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G6, Livingston Winter 2018 Membro di Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 69
Tutti i Tempi: 5,867
