Salta al contenuto principale
Shark Rocket Powerhead AH401 Post-Motor Filter Replacement
Cosa ti serve
  1. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Dust Cup: passo 1, immagine 1 di 3 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Dust Cup: passo 1, immagine 2 di 3 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Dust Cup: passo 1, immagine 3 di 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  2. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 2, immagine 1 di 2 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 2, immagine 2 di 2
    • Remove the dust cup by lifting it off the dock.
  3. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Filter Grille: passo 3, immagine 1 di 2 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Filter Grille: passo 3, immagine 2 di 2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  4. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 4, immagine 1 di 2 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement: passo 4, immagine 2 di 2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  5. Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Post-Motor Filter: passo 5, immagine 1 di 2 Shark Rocket Powerhead AH401 Post-Motor Filter Replacement, Post-Motor Filter: passo 5, immagine 2 di 2
    • Remove the filter by pulling it out and away from the device with your hand.
Conclusione
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 670
