Salta al contenuto principale
Shark Rocket Powerhead AH401 Panel Screws Replacement
Cosa ti serve
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: passo 1, immagine 1 di 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: passo 1, immagine 2 di 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: passo 1, immagine 3 di 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 2, immagine 1 di 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 2, immagine 2 di 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: passo 3, immagine 1 di 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: passo 3, immagine 2 di 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: passo 3, immagine 3 di 3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 4, immagine 1 di 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: passo 4, immagine 2 di 2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: passo 5, immagine 1 di 2 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: passo 5, immagine 2 di 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Conclusione
Toan Pham
Membro da: 01/24/18
269 Reputazione
3 Guide realizzate
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 960
