Salta al contenuto principale
Shark Rocket Powerhead AH401 Motor Replacement
Cosa ti serve
  1. Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: passo 1, immagine 1 di 3 Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: passo 1, immagine 2 di 3 Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: passo 1, immagine 3 di 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motor Replacement: passo 2, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 2, immagine 2 di 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motor Replacement, Back Panel Screws: passo 3, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement, Back Panel Screws: passo 3, immagine 2 di 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  4. Shark Rocket Powerhead AH401 Motor Replacement, Filter Grille: passo 4, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement, Filter Grille: passo 4, immagine 2 di 2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Shark Rocket Powerhead AH401 Motor Replacement: passo 5, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 5, immagine 2 di 2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  6. Shark Rocket Powerhead AH401 Motor Replacement, Belt: passo 6, immagine 1 di 1
    • Remove the four screws by rotating counter-clockwise:
    • One 12 mm screw with a T10 Torx screwdriver
    • Three 14 mm screw with a T15 Torx screwdriver
  7. Shark Rocket Powerhead AH401 Motor Replacement: passo 7, immagine 1 di 3 Shark Rocket Powerhead AH401 Motor Replacement: passo 7, immagine 2 di 3 Shark Rocket Powerhead AH401 Motor Replacement: passo 7, immagine 3 di 3
    • Remove the grey filter plate by simply lifting upward.
    • Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motor Replacement: passo 8, immagine 1 di 1
    • Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  9. Shark Rocket Powerhead AH401 Motor Replacement: passo 9, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 9, immagine 2 di 2
    • Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
  10. Shark Rocket Powerhead AH401 Motor Replacement: passo 10, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 10, immagine 2 di 2
    • Remove the motor compartment panel by lifting up and away from the device.
  11. Shark Rocket Powerhead AH401 Motor Replacement: passo 11, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 11, immagine 2 di 2
    • Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
  12. Shark Rocket Powerhead AH401 Motor Replacement: passo 12, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 12, immagine 2 di 2
    • Disconnect the motor side panel by lifting the motor and panel up and out.
    • This step may require some wiggling to loosen the panel before it becomes free.
  13. Shark Rocket Powerhead AH401 Motor Replacement: passo 13, immagine 1 di 1
    • Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
    • This screw allows the side panel to be removed.
  14. Shark Rocket Powerhead AH401 Motor Replacement: passo 14, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 14, immagine 2 di 2
    • Remove the side panel by pulling the panel out and away from the motor.
    • The side panel is connected with clips which connect near the brushroll axle.
  15. Shark Rocket Powerhead AH401 Motor Replacement: passo 15, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 15, immagine 2 di 2
    • Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
    • The screws only need to be loosened in order to free the belt.
  16. Shark Rocket Powerhead AH401 Motor Replacement: passo 16, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 16, immagine 2 di 2
    • Remove the belt by pulling the belt away from the axle.
  17. Shark Rocket Powerhead AH401 Motor Replacement, Motor: passo 17, immagine 1 di 1
    • Remove two 16mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  18. Shark Rocket Powerhead AH401 Motor Replacement: passo 18, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 18, immagine 2 di 2
    • Remove the belt-assembly unit by pulling the belt-assembly unit away from the motor.
  19. Shark Rocket Powerhead AH401 Motor Replacement: passo 19, immagine 1 di 2 Shark Rocket Powerhead AH401 Motor Replacement: passo 19, immagine 2 di 2
    • Rotate the motor unit over so that the wires are exposed.
    • Cut wires with cutting pliers to release the motor.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,938
