Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
This guide will show you how to replace the brushroll on your Shark Rocket Powerhead AH401 if it is damaged, needs cleaning, or you are trying to change the type of brushroll. Be careful of any hazardous materials your brushroll could have picked up before grabbing it.
  1. Ensure the device is turned off and unplugged from any power source before beginning work. Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover. Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Lift the brushroll out by pulling the tab labeled "pull". Lift the brushroll out by pulling the tab labeled "pull".
    • Lift the brushroll out by pulling the tab labeled "pull".
Conclusione
Toan Pham
Membro da: 24/01/2018
245 Reputazione
3 Guide realizzate
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 162
