Salta al contenuto principale
Shark Rocket Powerhead AH401 Brushroll Cap Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: passo 1, immagine 1 di 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: passo 1, immagine 2 di 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: passo 1, immagine 3 di 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Cap Replacement: passo 2, immagine 1 di 2 Shark Rocket Powerhead AH401 Brushroll Cap Replacement: passo 2, immagine 2 di 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: passo 3, immagine 1 di 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: passo 3, immagine 2 di 3 Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: passo 3, immagine 3 di 3
    • Remove the cap by pushing the "pull" tab.
Conclusione
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 986
