Introduzione
Over time, the belt will wear off, which will cause the brushroll to stop rolling/spinning. This guide will demonstrate how to remove the belt properly. The belt is attached to the motor but the motor does not need to be removed. The screws holding the motor in place will have to be loosened in order for the belt to come off.
Cosa ti serve
Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
Lift the brushroll cover upward.
Flip the device over so that the bottom is face up.
Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
Two 14 mm Torx screws
Two 16 mm Torx screws
Four 21 mm Torx screws
Push inward on the top of the filter grille where it says "Push."
Lift the filter grille upward.
Remove the four screws by rotating counter-clockwise:
One 12 mm screw with a T10 Torx screwdriver
Three 14 mm screw with a T15 Torx screwdriver
Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
I can't complete this step; the airpath grille is under a panel. I'm not able to remove this panel, maybe I'm missing something?
Remove the motor compartment panel by lifting up and away from the device.
The trick to removing this motor compartment panel: Wiggle it loose first. Then get an index and middle finger under the FRONT-LEFT L-shaped section of the panel (to the left of the screw hole, behind the spring mechanism). PULL STRAIGHT UP. You are going to likely get uncomfortable with the amount of pressure this requires and you might think you will break it. Keep working at it. Index and middle finger lifting it straight up. When it comes up, the spring mechanism might fall off. It's okay. You didn't break it. The motor compartment panel will pop off (up) eventually.
Thank you for responding! Is this what you mean? I can lift the left side a bit, but the right side near the black motor vent is not budging.
I took a photo but I can't figure out how to insert it in replies.
Susang -
Altre 10 persone hanno completato questa guida.
15 Commenti
These instructions were fantastic accept for one section. On Step 9 you never mention to first remove the Motor Compartment Panel before removing the airpath grille. The picture just shows the panel already removed. Otherwise, I followed the directions forwards and backwards and I was successful!! I went to the local vacuum repair store to purchase a new belt. They did not have the Shark belt so I purchased the Bissell BIBL, BELT geared 80R4, 47A2 for $3.50 and it worked perfectly!!
there is a hidden screw on the outside of the compartment/ motor side where the handle mets the motor compartment panel / in the corner iif i could leave a pic i would.
nm1hart -
is the Shark 400 and 401 the same in changing the dive belt?
What is the replacement belt part#? Did I miss that somewhere here? I can’t find it on their web site or anywhere else on line using the AH401 model #, thanks
I have an AH452 and the belt number is 4315 SC or Gates # 192-3GT6-SAR
Also, my model requires the TR drivers (security torx drivers with hole in the middle) which isn’t clear in this instruction
Great step-by-step instructions. I thought the belt was broken on my Model AH401 but when I finally got to to the drive mechanism, I discovered that the metal brush roller axel had broken away from the white plastic gear (shown in pics 15 and 16). It looks like the gear was just epoxied to the axel bolt head.
My unit also needed security torx drivers to remove all of the torx screws.
I found the same problem, along with tearing my hair out. 😱
Susang -
I followed this to a tee and it worked. The only sad part to it is when i got toward the end i quickly found out that the belt was intact but my motor was frozen internally. Locked up!!! not worth replacing in that case through all away :)
Could you explain how to get the motor compartment panel off. Another poster said there is a hidden screw, but I can't find it. Thanks!
Susang -
I finally found the screw to remove the panel that holds down the the motor cover. It is actually in back of, and underneath, (but behind), the motor cover. Unfortunately words don't describe it accurately. It is really too bad that Ifixit doesn't allow commenters to post a picture in this reply box. That would make all the difference in the world. Also, I'm putting a curse on Shark! They really put a lot of time and effort into creating an almost impenetrable Chinese box. I've probably ruined the vacuum. Sadly, I really loved this vacuum, which is why I bothered to bother...The belt is not broken, just loose, and it looks like the white gear wheel is broken from the metal post that turns the beater brush. Oh well.
