Introduzione
Is your Shark Rocket IX141 not gliding properly along surfaces (having tottery or janky movement), getting stuck, or not moving at all? If so, the wheels may have to be replaced. Without working wheels, your Shark Rocket IX141 will fail at its most basic functions, since the wheels are what allow movement.
Though taking off the wheels may appear daunting, following this guide will allow you to replace your Shark Rocket IX141's wheels quickly and efficiently.
Cosa ti serve
Press the indigo button and pull the vacuum stick away from the floor nozzle.
Flip the floor nozzle so the bottom part is facing up.
Use a TR10 Torx Security screwdriver to remove the two 20 mm screws.
