Salta al contenuto principale
Shark Rocket HV381 Brush Replacement
  1. Shark Rocket HV381 Brush Replacement, Brush: passo 1, immagine 1 di 2 Shark Rocket HV381 Brush Replacement, Brush: passo 1, immagine 2 di 2
    • On the top of the vacuum head is two grey "Brush Roller Access" buttons. Simultaneously press both buttons to eject the Roller Cover. Remove the Roller Cover by pulling it towards you and up.
  2. Shark Rocket HV381 Brush Replacement: passo 2, immagine 1 di 3 Shark Rocket HV381 Brush Replacement: passo 2, immagine 2 di 3 Shark Rocket HV381 Brush Replacement: passo 2, immagine 3 di 3
    • The "Pull Tab" tab is located at the right. Pull the Tab up and to the right for removal.
    • The Brush is sticky so hold the vacuum head with one hand and give the tab a moderate tug.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 697
