Introduzione
If your mop is not emitting steam then replacing the nozzle may help. Before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug the mop and empty the water tank for your safety.
Parti
Nessuna parte richiesta.
  1. Press the mop head release button to remove it from the steam mop body.
    • Press the mop head release button to remove it from the steam mop body.
  2. Remove the four 10mm screws holding the joint assembly to  the mop head with your Phillips #2 screwdriver.
    • Remove the four 10mm screws holding the joint assembly to the mop head with your Phillips #2 screwdriver.
  3. Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
    • Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Remove both screws.
  6. Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
    • Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
  7. Use needle nose pliers to compress metal clamp .
    • Use needle nose pliers to compress metal clamp .
  8. Pull the nozzle out of the tube.
    • Pull the nozzle out of the tube.
Conclusione
Michael Raymond
Membro da: 12/02/2018
145 Reputazione
1 Guida realizzata
USF Tampa, Team S15-G1, Boczar Spring 2018 Membro di USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 230
