Salta al contenuto principale
Shark Pet Perfect II Front Brush Motor Replacement
Cosa ti serve
  1. Shark Pet Perfect II Front Brush Motor Replacement, Front Belt: passo 1, immagine 1 di 1
    • Remove the motorized brush from the dust cup by pulling it apart.
  2. Shark Pet Perfect II Front Brush Motor Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
  3. Shark Pet Perfect II Front Brush Motor Replacement: passo 3, immagine 1 di 2 Shark Pet Perfect II Front Brush Motor Replacement: passo 3, immagine 2 di 2
    • Separate the motorized brush face plate by using a flat prying tool.
  4. Shark Pet Perfect II Front Brush Motor Replacement: passo 4, immagine 1 di 3 Shark Pet Perfect II Front Brush Motor Replacement: passo 4, immagine 2 di 3 Shark Pet Perfect II Front Brush Motor Replacement: passo 4, immagine 3 di 3
    • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
    • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
  5. Shark Pet Perfect II Front Brush Motor Replacement, Front Brush Motor: passo 5, immagine 1 di 3 Shark Pet Perfect II Front Brush Motor Replacement, Front Brush Motor: passo 5, immagine 2 di 3 Shark Pet Perfect II Front Brush Motor Replacement, Front Brush Motor: passo 5, immagine 3 di 3
    • Lift the motor from the motor mount.
    • Use a soldering tool to carefully soften the solder on the connectors.
    • If after re-soldering the wires to the motor doesn't cause it to begin functioning properly, you may attempt to replace it with another 18 volt DC electric hobby motor.
    • Manufacturer does not advertise exact specifications of motor. Attempt replacing motor as a last resort and do so at your own risk.
Conclusione
Documenti Allegati
Tanner Brown
Membro da: 06/27/17
459 Reputazione
3 Guide realizzate
UW Tacoma, Team S1-G5, Liner Summer 2017 Membro di UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Membri
8 Guide realizzate
2 Commenti
This is the closest I’ve come to finding out how to fix the motorized brush. Thank you. Everything works fine, but what I need now is the little white plastic piece that goes on the motor’s drive axle. Mine is cracked and keeps sliding off. Since Shark.com doesn’t go into this type of detail, is there a generic equivalent I can use? If so, where can I get one, or some. I suppose superglue would work, but I would rather get a new piece.
Ken Coil - Replica
Any idea where a can get replacement gears
bernieb627 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,433
