Salta al contenuto principale
Shark Pet Perfect II Front Belt Replacement
Cosa ti serve
  1. Shark Pet Perfect II Front Belt Replacement, Front Belt: passo 1, immagine 1 di 1
    • Remove the motorized brush from the dust cup by pulling it apart.
  2. Shark Pet Perfect II Front Belt Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
  3. Shark Pet Perfect II Front Belt Replacement: passo 3, immagine 1 di 2 Shark Pet Perfect II Front Belt Replacement: passo 3, immagine 2 di 2
    • Separate the motorized brush face plate by using a flat prying tool.
  4. Shark Pet Perfect II Front Belt Replacement: passo 4, immagine 1 di 3 Shark Pet Perfect II Front Belt Replacement: passo 4, immagine 2 di 3 Shark Pet Perfect II Front Belt Replacement: passo 4, immagine 3 di 3
    • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
    • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
Conclusione
Documenti Allegati
Tanner Brown
Membro da: 06/27/17
459 Reputazione
3 Guide realizzate
UW Tacoma, Team S1-G5, Liner Summer 2017 Membro di UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Membri
8 Guide realizzate
Un commento
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
Aaron Woods - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 781
