Introduzione
This step by step guide will help you remove the battery from its compartment. The battery can be easily removed in 4 steps, with very few tools. Care should be used when handling the battery.
Cosa ti serve
Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
Altre 4 persone hanno completato questa guida.
Documenti Allegati
12Commenti sulla guida
Removed the single screw but cover will not come off. What do you do?
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
NO. Requires batteries.
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
