Salta al contenuto principale
Shark Navigator Roller Brush Replacement
Cosa ti serve
  1. Shark Navigator Roller Brush Replacement, Roller Brush Compartment: passo 1, immagine 1 di 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Replacement: passo 2, immagine 1 di 2 Shark Navigator Roller Brush Replacement: passo 2, immagine 2 di 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Replacement: passo 3, immagine 1 di 1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Roller Brush Replacement, Roller Brush: passo 4, immagine 1 di 1
    • Lift the roller brush out of its holders.
Conclusione
Altre 42 persone hanno completato questa guida.
Jeremiah Shyne
Membro da: 03/27/15
1.403 Reputazione
2 Guide realizzate
35 Commenti
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - Replica
Very helpful and easy. Thank you.
Kristi cox - Replica
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - Replica
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - Replica
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 196
Tutti i Tempi: 98,913
