Salta al contenuto principale
Shark Navigator Motor Replacement
Cosa ti serve
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: passo 1, immagine 1 di 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: passo 2, immagine 1 di 2 Shark Navigator Motor Replacement: passo 2, immagine 2 di 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: passo 3, immagine 1 di 1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: passo 4, immagine 1 di 1
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
Conclusione
Molina Oung
Membro da: 03/27/15
265 Reputazione
1 Guida realizzata
4 Commenti
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - Replica
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - Replica
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 72
Tutti i Tempi: 14,480
