Salta al contenuto principale
Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: passo 1, immagine 1 di 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: passo 1, immagine 2 di 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: passo 1, immagine 3 di 3
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: passo 2, immagine 1 di 2 Shark Navigator Lightweight Upright Hose Replacement: passo 2, immagine 2 di 2
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: passo 3, immagine 1 di 3 Shark Navigator Lightweight Upright Hose Replacement: passo 3, immagine 2 di 3 Shark Navigator Lightweight Upright Hose Replacement: passo 3, immagine 3 di 3
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
Conclusione
Kahye Yu
Membro da: 10/02/17
446 Reputazione
2 Guide realizzate
Cal Poly, Team S4-G6, Livingston Fall 2017 Membro di Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Membri
12 Guide realizzate
3 Commenti
Where can I find a replacement hose?
Vance Payne - Replica
How to replace the bottom pick up hose.
rgg20319 - Replica
How to fix the bottom hose?
rgg20319 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 72
Tutti i Tempi: 3,304
