Salta al contenuto principale
Shark Navigator Lightweight Upright Dust Cup Replacement
  1. Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: passo 1, immagine 1 di 2 Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: passo 1, immagine 2 di 2
    • Press down on the black, rubber ballish button located on the top of the vacuum.
    • Pull back simultaneous on the plastic handle and remove the dust container.
  2. Shark Navigator Lightweight Upright Dust Cup Replacement: passo 2, immagine 1 di 3 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 2, immagine 2 di 3 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 2, immagine 3 di 3
    • Press the plastic tab in, located on the front of the dust container.
    • Pull up simultaneously on the plastic handle.
  3. Shark Navigator Lightweight Upright Dust Cup Replacement: passo 3, immagine 1 di 2 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 3, immagine 2 di 2
    • Remove the dust cup from the inside of the dust container.
  4. Shark Navigator Lightweight Upright Dust Cup Replacement: passo 4, immagine 1 di 3 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 4, immagine 2 di 3 Shark Navigator Lightweight Upright Dust Cup Replacement: passo 4, immagine 3 di 3
    • Push in the red tab located on the side of the dust cup.
    • Open the dust cup simultaneously with the cone-half pointing downwards.
    • Separate the two halves.
Conclusione
Kahye Yu
Membro da: 10/02/17
446 Reputazione
2 Guide realizzate
Cal Poly, Team S4-G6, Livingston Fall 2017 Membro di Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 79
Tutti i Tempi: 3,481
