Salta al contenuto principale
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: passo 1, immagine 1 di 1
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 2, immagine 1 di 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 2, immagine 2 di 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 2, immagine 3 di 3
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 3, immagine 1 di 2 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 3, immagine 2 di 2
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 4, immagine 1 di 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 4, immagine 2 di 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 4, immagine 3 di 3
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 5, immagine 1 di 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 5, immagine 2 di 3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: passo 5, immagine 3 di 3
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S15-G2, Livingston Fall 2017 Membro di Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 39
Tutti i Tempi: 4,923
