Salta al contenuto principale
Shark Navigator HEPA Filter Replacement
  1. Shark Navigator HEPA Filter Replacement, HEPA Filter: passo 1, immagine 1 di 1
    • On the front of the vacuum, locate the latch on the bottom of the front vent.
  2. Shark Navigator HEPA Filter Replacement: passo 2, immagine 1 di 1
    • Press up on the latch and remove the front vent
  3. Shark Navigator HEPA Filter Replacement: passo 3, immagine 1 di 1
    • Lift the HEPA filter out of the vacuum
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
the taking out worked great but putting the new one back in is impossible.......will not fit i will not buy a new vac because of this........
lillian kresge - Replica
this is the second filter that i have purchased and it is the same...does not fit properly i could use a hammer to it?????
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 48
Tutti i Tempi: 12,169
