Salta al contenuto principale
Shark Lift-Away Professional Steam Pocket Mop Handle Replacement
Cosa ti serve
  1. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement, Mop Handle: passo 1, immagine 1 di 1
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 2, immagine 1 di 1
    • Place the Steam Pocket Mop face down on a flat surface.
    • Take note of the placement of the handle; the side labelled "front" should should face forward.
  3. Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 3, immagine 1 di 3 Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 3, immagine 2 di 3 Shark Lift-Away Professional Steam Pocket Mop Handle Replacement: passo 3, immagine 3 di 3
    • Remove the screw located underneath the cord holder.
    • Turn the screwdriver counter-clockwise to loosen the screw from its slot.
    • This is a long screw and will take time to remove.
Conclusione
To disassemble your device, follow these instructions in reverse order.
Nancy K Do
Membro da: 10/17/18
165 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G3, Rose Fall 2018 Membro di UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,240
