Salta al contenuto principale
Shark IQ AV993 Wheels Replacement
Cosa ti serve
  1. Shark IQ AV993 Wheels Replacement, Battery: passo 1, immagine 1 di 1
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Wheels Replacement: passo 2, immagine 1 di 1
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Wheels Replacement, Bumper: passo 3, immagine 1 di 2 Shark IQ AV993 Wheels Replacement, Bumper: passo 3, immagine 2 di 2
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Wheels Replacement: passo 4, immagine 1 di 1
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Wheels Replacement: passo 5, immagine 1 di 1
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
  6. Shark IQ AV993 Wheels Replacement, Wheels: passo 6, immagine 1 di 2 Shark IQ AV993 Wheels Replacement, Wheels: passo 6, immagine 2 di 2
    • Flip over the vacuum so that the bottom is facing upwards.
    • Remove the five 14 mm screws using a T20 Torx screwdriver.
  7. Shark IQ AV993 Wheels Replacement: passo 7, immagine 1 di 1
    • Pull upward on the wheel to remove the wheel housing.
    • Carefully remove this as there is a clip connecting to the wheel.
    • Press the tab on the clip and slide the wires out of the housing.
    • Repeat this step and the previous step for the other wheel assembly.
Conclusione
Marc Farah
Membro da: 10/26/22
94 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Membro di UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 222
