Salta al contenuto principale
Shark ION Robot S87 Bumper Replacement
Cosa ti serve
  1. Shark ION Robot S87 Bumper Replacement, Bumper: passo 1, immagine 1 di 1
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: passo 2, immagine 1 di 3 Shark ION Robot S87 Bumper Replacement: passo 2, immagine 2 di 3 Shark ION Robot S87 Bumper Replacement: passo 2, immagine 3 di 3
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: passo 3, immagine 1 di 1
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
Where can I buy a new bumper?
Lacy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 92
Tutti i Tempi: 13,506
